Hi all
Help, we just bought an 89 Bronco, needed some work, radiator and more. Will start eventually (with aerosol) and run fine, as soon as you turn it off it refuses to fire again. Has new plugs, wire, battery, starter.
I have seen relays and ignition module mentioned. Does anyone have any ideas ... the garage wanted to change the head gasket! Help!
I am stuck in NJ with this vehicle and need to get back to SC and am running out of money ....
Bronco Cranks, Won't Fire
Guest_drwyrehead_*
, Mar 27 2004 06:44 PM
9 replies to this topic
Posted 28 March 2004 - 05:50 AM
Welcome to the B Zone.
You might want to check the coil. Next thing to check are the fuel filter /s, I have two on my 90. One is on the frame rail near the rear axel the other one is where the fuel line starts to go up at the fire wall.
You'll also want to inspect the relays on the driver side wheel well, North East trucks have a tendency to build up a lot of corrosion in the plugs. Take an emory board and wire brush and clean the contacts on the relays and inside the plug.
I am assuming the engine stays running until you turn it off, or is it shutting down on it's own? If it is shutting down on it's own, how long does it run for?
90 Bronco Full Size
Police Package
351W
E4OD
31" Tires
Police Package
351W
E4OD
31" Tires
Posted 28 March 2004 - 05:52 AM
Also check the gap on the plugs. The gap should be set to 0.044 inch.
90 Bronco Full Size
Police Package
351W
E4OD
31" Tires
Police Package
351W
E4OD
31" Tires
Posted 29 March 2004 - 04:28 AM
Sounds like the coil is bad. When it heats / warms up it dies.
90 Bronco Full Size
Police Package
351W
E4OD
31" Tires
Police Package
351W
E4OD
31" Tires
#6 Guest_letrain_*
Posted 29 March 2004 - 07:24 AM
first check to see if there is spark by pulling out the cable from the middle of your distributer and holding it near metal (dont get your hand near the end it will hurt if it sparks), if it sparks have then plug it back in and have someone hit the bottom of the gas tank with a stick hard while someone else cranks it over, if it starts then its your fuel pump that is going bad.
Posted 29 March 2004 - 11:20 PM
It does sound like it could be that ignition module. If the autozone.com website is working, you can search their repair library for info. (Check tech articles here at BZ for a link). You may also have a problem with engine timing or the computer.
#10 Guest_mike g_*
Posted 12 April 2004 - 05:22 AM
I just wanted to add this little comment ,my 87 bronco would run for a couple of days with no problems then just shut down.What i found was the wire going to the coil was broken off on the positive side of the coil couldn't see it with the shrink rap on it took me 2 days to find it.ran a jumper wire from the bat to the + side of the coil to get it home.
