I have an 1988 F350 with a fully charged battery. I am getting power across the +/- of the regulator. But that is where it stops. Lights don't work key on or off . Nothing on the dash N/ radio.
Before find "Ford "F" Zone" It was suggested on another site the issue. may be some little doohickey that may have been broke. After pulled the steering column cover, I found that was not the issue.
The same thing happened a few weeks back. Probably because I don't know any better. I sprayed electrical contact cleaner in the ignition switch. That worked , this time not.. Where should I start to solve this issue
Thank You Edward Clark
