First post. Glad to be here. I recently purchased a 1985 F150 Single Cab 4x4 with 351W Engine. Shortly after purchase the blinkers started acting up. I replaced the Flasher Relay and all fuses. Every blinker works except for the Driver's Side Front. Hazards all function as well. When left turn signal is engaged the dash light does not come on, but there is still the "blinking sound". I've tried researching what could be the problem but haven't seen any clear answers. Any help is greatly appreciated.
Turn Signal Malfunction
85Fordx4
, Aug 01 2016 05:25 PM
1985 F150 Turn Signal Blinker Flasher Lights 351W 4x4
Posted 04 August 2016 - 05:35 AM
Yo 85,
I THINK THE 85 have a seperate flasher for turn signals and hazards. Check for one behind the fuse panel, believe it is for hazards.
One Indicator light doesn't light ..
- ***Check the bulb and socket (for corrosion & Wiring issues) on the Front driver side***
- ***Check the left indicator light bulb***
- Check the flasher by substitution
by..
http://rogerspure.pr...urnSignals.html
by..
Thanks to All Who Serve
Also tagged with one or more of these keywords: 1985, F150, Turn Signal, Blinker, Flasher, Lights, 351W, 4x4
Technical Support →
80-96 Ford Truck Tech Support →
1985 F150 351W Smog Pump/Emissions RemovalStarted by 85Fordx4 , 01 Aug 2016 ![]() |
Welcome To FordFZone.com! →
Introductions →
A newbie hereStarted by Elena Valentino , 03 Nov 2013 ![]() |
