Driveshaft
#1 Guest_fordblue_*
Guest_fordblue_*
Posted 21 April 2004 - 07:10 PM
Put 35 tires on,now my u joint on my rear drive shaft keeps twisting,breaking...help!!!
#2 Txquadhunter
Txquadhunter
    F-Series Maniac
  • Moderators
  • PipPipPipPipPip
  • 241 posts
Posted 21 April 2004 - 07:37 PM
did you lift the bronco? if so the pinion angle could be off causing the trouible. If not be sure to use good U-joints. the cheap auto zone joints won't cut it. also the u-joints are the weakiest link in your driveline.
#3 Billz4x4z
Billz4x4z
    F-Series Maniac
  • PipPipPipPipPip
  • 107 posts
  • Interests:Trucks,4 Wheelin,Workin on Stuff,campin,the outdoors,NASCAR,meetin new people to go wheelin with,Truck shows family time
Posted 23 April 2004 - 04:37 PM
With the bigger tires your gonna get alot more twist of the axle,especially if your using a lift block,thats gonna eat u-joints on a regular basis.Like what was said in the previous post if ya did lift it you driveline may be outta line also.
Posted ImagePosted ImagePosted Image
#4 Guest_Tom Kelly_*
Guest_Tom Kelly_*
Posted 26 April 2004 - 02:09 PM
Hello! Where can I get or order a bug deflector for my 79 Ford F150 ? Thanks Tom
