Limited-slip Diffs
#1 Guest_cleo_*
Posted 29 April 2004 - 03:02 PM
Posted 29 April 2004 - 09:53 PM
#4 Guest_cleo_*
Posted 30 April 2004 - 05:53 PM
#5 Guest_CADster_*
Posted 04 May 2004 - 10:35 PM
i dont think i would put one in ... i think with 8.8 you have to remove the gears (its not a floater). reinstalling these will be hard and doing it wrong will cut their life greatly.Right now all I have is a two wheel drive Bronco.� Both front and rear are open diffs, Randy's tells me that a truetrax is a limited slip unit that requires no modification to install.� But I have no experience with limited slip diffs so any advice will help.
i would go to a pro to have it installed (so i would take it to my best friend .. you may not be so lucky)
what you go for sale/trade southerntrax ????
my diff needs clutche/pads .. it may be better to just pick up a new chunk.
(my truck has factory front and rear posi/limited slip)
#6 Guest_Gunner_*
Posted 05 May 2004 - 06:38 AM
well the first thing i would do is sell it and buy a 4x4 like a bronco is supposed to be. they should kill the guy who thought that a 2x bronco was a good idea. but that is my opnionRight now all I have is a two wheel drive Bronco. Both front and rear are open diffs, Randy's tells me that a truetrax is a limited slip unit that requires no modification to install. But I have no experience with limited slip diffs so any advice will help.
#7 Guest_Stephen Hawk_*
Posted 09 May 2004 - 12:09 AM
"Right now all I have is a two wheel drive Bronco. Both front and rear are open diffs,"
