Help, I got a vibration. I just bought a new drive shaft from Jeff's, but it didn't help. It happens under a light load,I can get over it by giving it gas or less gas. The Bronco has a 130000 on it and runs good.Hate the thought of a new tranny.But I don't think it's the rear end. The tranny guys around don't fix um they rebuild um. Thanks Brian
Got A Vibration
Guest_Brian_*
, Jun 04 2004 04:56 PM
Posted 04 June 2004 - 07:19 PM
Gee Brian, I don't think it is in your transmission. I would suspect something in the rear end area. Perhaps a bearing starting to wear, the more gas less gas comment indicates you are putting a litttle extra pressure on something and that causes it to quiet down.
I don't remember the post exactly, but there was one on vibration the was caused by a wheel bearing. It had gone long enough to start cutting thru the axle.
