I'VE CHANGED THE CAP, ROTOR, COIL, THE MODULE ON THE DIST. STILL NO SPARK TO THE PPLUGS AND NO SPARK TO THE COIL. THERE IS NO POWER BEFORE THE COIL OR AFTER. IT IS MANUAL TRANS. AND A/C. V-6, 2.9. ANYBODY HAVE AN IDEA? <' />
1985 Bronco Ii
Guest_rjwright_*
, Jul 06 2004 09:06 PM
Posted 07 July 2004 - 05:40 PM
looking at the haynes repair manual and the electric diagram it appears that you should check the red lightblue wire running from your starter relay to your distributor modual for power. then if not check your starter relay as the power from the battery is supplied there. check for power from the battery at the starter motor between ground and the red wire . If you have power there and not between the lightblue wire and the other side of the relay then i would suspect your relay. Hope that this helps.
