I have a 96 bronco, and can't keep the fan belt on. My water pump went out. Had it changed, and ever since the fan belt keeps coming off... destroying everything. Could the belt be getting put on backwards? any other suggestions?
Fan Belt
dbrown198
, Aug 09 2004 05:54 PM
Posted 09 August 2004 - 10:37 PM
I would suspect that one of the pulleys is out of line.
Stand at the side of the truck, look across the face of the pulleys, does one look out of place when compared to the others?
Was any thing else replaced when the w/pump was done? (ie tensioners, idler pulley etc?)
Posted 10 August 2004 - 04:45 AM
I agree, it definately sounds like a alignment problem or the belt tensioner idler pully. It is possible tht an idler pully is shot and needs sreplacement.
Good Luck,
Good Luck,
