Body Lift Vs. Suspension Lift
Guest_broncoshell_*
Posted 17 August 2004 - 06:51 AM
Guest_Freewheel Burning_*
Posted 19 August 2004 - 11:44 AM
The frame of your Bronco is the center point, with the body bolted to the top of it, and the suspension bolted to the bottom of it. With a body lift, you put spacers between the body and frame, thereby raising the body while the suspension and frame stay in the same place. This is good for giving you extra fender clearance. With a suspension lift, you are putting in taller springs which adds space between suspension and frame. This raises everything but the axles. The axles only get raised when you put the bigger tires on that you now have room for!
I just put the Superlift 4" suspension lift in my 79, which I highly recommend. I did it in my driveway, with basic hand tools, and it took me about three weeks of evenings and Saturdays. Broncograveyard.com and 4 Wheel Parts got most of my business. Good luck.
Guest_billybroncojr_*
Posted 19 August 2004 - 01:18 PM
Later,
Jeff
Guest_battered_bronco_*
Posted 20 August 2004 - 12:09 AM
body lift raises the body but the motor/trans is only lifted by the increased tire size
so with the stock~29 inch tires swaped for 34s and 4 inch lift is like ~9 inches
personally i would go with both 2 body/2 suspention unless its only for "looks" then stay with body(but 3 inch body lift on a 78/79 bronco will reck your lower column
i think you can put 33s on a ol bronco with a body lift it will just look better
start with a cheap/"easy" 1 1/2(pref) - 3 body lift and new body mounts
most suspention lifts seem to bee real soft too
and stay away from axle block
Posted 24 August 2004 - 06:15 AM
actually swapping from 29's to 34's will only give you a 2.5 inches more lift plus the 4 in. susp. lift which only makes 6.5 inches more of lift. the best way i can think to explain it is to measure form the center of a tire and then to the outside of it, do the same with the other tire, then difference it the ammount of lift/loss on the tire swap
Posted 19 January 2007 - 05:01 PM
i rec suspension, its more money but it looks better. a did a 4 inch in my 77 f150 i had, worked well but i wanted bigger. then i bought a 6 inch super lift, had to get the driveline extended. cost was about 450.00 dollars on top of the lift. i loved the 6 inch with 38 inch tires. keep in mind your gears when you decide how big youre going, rec at least 4.11s with 38s.This will sound as if I'm stupid but I am fairly new to 4*4. What is the difference between a body lift and a suspension lift, do you need both to lift up a truck, which is better, and whats the best names in the industry to use?
Posted 30 March 2008 - 03:25 PM
Posted 23 September 2008 - 08:39 PM
