Hello,
I recently bought a 88 bronco. It does have a 2in lift on it but it was on it when i bought it. My problem is that is wont turn to the left very far, it turns to the right fine tho. what do you think the problem is? Please help!!!!!!
Steering Trouble
Guest_mytoy_*
, Feb 07 2004 09:50 PM
#3 Guest_87Bronco351_*
Posted 09 February 2004 - 07:07 PM
Well one suggestion is set your wheels straight, and look under your truck at your pitman arm to see if it is straight if it is off to one side your steering linkage could be offset to one side allowing you to turn just a little but like i said this is just a suggestion i could be totally wrong. Also check your power steering fluid. also you said it had a lift, check if you have a steering stabilizer if you do that could be a problem.
