My 87's rear window does not work, and it is stuck in the down possition. I need to get it up so i can see if the motor is bad or what? the chilton repair manual is no help. But befor i go through the trouble of that, is there any other problems that i should check first???
Rear Window
Guest_87Bronco351_*
, Feb 09 2004 03:59 PM
#2 Guest_7.3crawler_*
Posted 09 February 2004 - 08:45 PM
Remove the left tailight assembly, the electrical wires for the window will be right there. the ground wire for the window motor is screwed to the body it often gets corroded. There is also a 12v power wire with abullet type connector that corrodes away. If power and ground are good, and all else fails, have someone hold up on the window switch while you smack the inside of the door with a large rubber mallet! Dan.
#3 Guest_Ice Man 860_*
Posted 10 February 2004 - 02:05 PM
Ive had similar problems with my '89. check the window regulator bracket and roller, u can get at em if u pull the glass up a little bit with the access panel off. in my case one of the rolers rusted off and had to be replaced, you can get all of thoes parts from the bronco graveyard
also check the the posting on the second page of this forum called 96 Bronco Rear Window, posted by mcbmg95
