o-k, my driveshaft is trashed and a shop said they could fix it for a couple hundred bucks. am i better off replacing it? and is there one off of another year bronco that will work? i have a 87 302 with AOD A/T.
87 Fsb Rear Driveshaft
Guest_dasilvalucas_*
, Feb 09 2004 07:46 PM
5 replies to this topic
#6 Guest_89 Bronco_*
Posted 19 February 2004 - 01:21 PM
I wouldnt try the junk yard. Have you ever seen what happens to a drive shaft after a truck/bronco is picked up by a forklift?....not prett. 9 out of 10 times it's bent. If its in a junkyard you might be buying what you already have. The Ford dealer will hit you hard. I have mine custom made. Your local 4x4 shop should be able to tell you where you can go to get one made. Its not cheap but it should be cheaper than the dealership. Keep in mind that the rear shaft should be balanced....if not you will have a massive vibration at high speeds. Jason 89 bronco
