I just bought a 86 ford bronco, 302 fuel injected, and i want to know if i can swap frontends from a newer bronco, mainly the lights and grille, i have to replace the fenders and the core support is mangled on the drivers side bottom corner and can be replaced as necessary, is it possible to do these conversions, also I am looking for a 351 that is carbed, i need to switch my truck over from the fuel injection to carb and need some ideas and suggestions. Any help would be greatly appreciated.
86 Bronco To 96 Frontend
Guest_mcateecw_*
, Oct 12 2004 05:42 AM
10 replies to this topic
Posted 12 October 2004 - 03:07 PM
1)It shouldn't be too much of a hassle more than you have going. I'm not sure if the headligh/wiring harnesses are the same... You'll need a new hood and fenders, as well as the little chingadera strip below the grill. A new grill too. Also, keep in mind the body lines are different. The '86 I'm pretty sure has an indentation just abouve the fender arches from front to rear (similar to the '85 if not identical); and I'm not 100% sure on this (did they change in '87??) so some one else help me out if I'm wrong.
2)Why change? a 5.0 fueli is pretty easy to get more power out of and the power#'s are not that much smaller then a 351W carbed
. Pretty much 95% of 5.0 Mustang go faster parts will bolt on. I don't see the reward being worth the hassle. (But then again, I DID convert to diesel....
Posted 15 October 2004 - 09:00 PM
OK heres the difference . This is an 80 to 86 body style notice the indented lower body line . http://fordtruckworl...-n-269768-pos-1
#11
Posted 15 October 2004 - 09:03 PM
And here is the 87 to 96 body style notice the flared out lower body line the pics should clear up any confusion . http://fordtruckworl...-n-363916-pos-1
