I need to replace my rear end, but have know idea what it is, dana?, 411? I do have a 88 parts truck with a 302, would it be compatible? thanks jfr
94 Eddie B 5.8 Rear End?
Guest_jfr bronco_*
, Feb 11 2004 03:48 PM
6 replies to this topic
Posted 12 February 2004 - 02:10 PM
your 94 has a 8.8" rearend. as for the gear ratio crawl under and find the tag on one of the diff. bolts. it'll have like 355 (3.55 ratio) or 3L55 (3.55LS ratio). your parts 88 will also ave the 8.8" rearend that'll slide right under if the same gear ratio. the only i'm not sure on if the 88 has the ABS/speed sencor in the rear which the 94 will need for the speedo to work. hope this helps
Posted 12 February 2004 - 07:40 PM
i'd first check to see if the 88 has the sencor first. because most 8.8's have it. i'm not 100% sure but if the 88 has a OD tranny they have the sencor. but if not and the 88 has the same gear ratio swap the guts in it. but check around to see if 88 has the ABS/speedo port.
#6 Guest_Stomper4x4_*
Posted 12 February 2004 - 10:48 PM
My 89 has the abs sensor on the rear.
Check this site, it'll tell you what the axle code on the sticker inside the drivers door means as far as axle ratio
http://www.broncodat...ce/axlecode.htm
