i have a 79 bronco with a dana 44 front. i also have a 78 f250. ihave put the rear dana 60 from the f250 in my bronco and would like to swap the front. i would also like to keep the coil suspension. i heard that i can swap the steering knuckles out to get the bigger bearings, brakes, and eight lugs. i was wondering if the dana 44 from the bronco and the dana 44hd are the same from the knuckles in. any info would be great. thanks.
3/4 Ton Conversion
Guest_brianmelnikow_*
, Nov 18 2004 09:47 PM
Posted 27 November 2004 - 05:49 PM
Other than the thickness of the axle tube, yep
Posted 12 December 2004 - 06:16 PM
on the other hand if price is an issue,just swap everything over from the danna 44 from the f250 spindle,etc.only thig you wil have to do is modify your brae lines or just swap them from the f250
![Posted Image](http://img.photobucket.com/albums/v111/Billzfordz/FordTrucks.jpg)
![Posted Image](http://img.photobucket.com/albums/v111/Billzfordz/Fordtough.jpg)
![Posted Image](http://img.photobucket.com/albums/v111/Billzfordz/cs60055.jpg)
