i plan on running 6" superflex coils moved up 2" to lift me 4". i have 3" drop brackets so should i keep them and run 2 deg bushings? or should i lose the drop brackets and run ? deg bushings? i will be trying a wristed arm. for steering will a drop trac bar and drop pitman be decent? this truck will never see long trips probably its just my toy. also what are side affects of coil bow? im on a tight budget (im 20) so i cant afford any aftermarket arms.
Yes Another Lift Question
texan79&96
, Dec 07 2004 12:57 PM
Posted 15 December 2004 - 09:03 PM
For a 4" lift, use 7 degree radius arm bushings if you don't use the drop brackets. Any lift 4" and over, it is suggested that you use a drop pitman arm and yes, use the drop track bar or your front axle will not be on center and it will also reduce your axle droop.
