Tailgate Rust
Posted 12 December 2004 - 04:50 PM
Posted 12 December 2004 - 07:15 PM
#8 Guest_Guest_Daddude_*
Posted 06 January 2005 - 09:01 AM
Thanks for the reply and I will check out JBG's catalog.I just received it the other day.Thanks again!I seen those on broncograveyard.com, but I only saw them listed for 66-77 Broncos.jeff's bronco graveyard carries the diamond plate panel....whole tailgates as well...going to pick mine up this weekend!
Posted 06 January 2005 - 06:17 PM
No offense intended, but actually that isn't the problem. There are two types of rust involved in the body, one from moisture dirt and salt. The other is galvonic rust which is a result of electrical current running thru the skin (starts mainly at welds and moves on from there).
There is no way to prevent water from gettting inside the tail gate. It is a good idea though, since the old hard weather stripping contributes to sctatching up the widow. You need to cut out all rust to get rid of it before putting on any new skin. If you don't it will continue to eat away at the tail gate. Once you have the rust cut out, seal the inside with something like POR15 which will seal any surface rust. Make sure the drain holes in the bottom are clear so when water gets in can drain out.
Posted 07 January 2005 - 10:10 PM
#11
Posted 08 January 2005 - 06:31 AM
#12
Posted 08 January 2005 - 02:49 PM
#13
Posted 08 January 2005 - 03:07 PM
I had forgotten about that untill BroncoForever mentioned the grease.
Ford tried and failed to seal that area with putty which after a year or two got hard and came out or just let the water seap in.
#14
Posted 13 January 2005 - 07:11 PM
