I was wondering if anyone had any experience with a "thump" in the rear end when the truck is first starting out and coming to a stop. I just had a rebuilt transmission put in and it is shifting great; however, I've always had this "thump" in the rear end. It seems to be more evident when the truck has been driven awhile.
Thanks for any input.
96 Bronco - Rear End Problems
Guest_Stephen Kelly_*
, Jan 07 2004 07:51 AM
Posted 08 January 2004 - 12:05 PM
If you come back here to read this -
Check a few things: make sure the Ubolts are still tight, keeping the spring pack tight to the spring perches on the axle. Make sure the spring perches themselves are rounded over at the ends. Have your rear diff checked out... the gears might be ruined
