[FONT=Arial][SIZE=7] I have a 1985 Bronco and it is stuck in 4Low. the linkage on the transfer case moves and it moves inside the transfer case but it will not disengage from 4low in any position.
What Can I Do?
What should i do?
Help!
Guest_CURSED BRONCO_*
, Feb 19 2004 05:00 PM
4 replies to this topic
Posted 19 February 2004 - 07:54 PM
if your under looking at the linkage and see it moving inside the Tcase. it sounds like a broke shift fork inside the case and time for a rebuild. but besure there is no play in the linkage first. because they have a little pastic gromlet that they slide in.
Posted 20 February 2004 - 02:11 AM
the broken shift fork is just what I was thinking also
