Where does the heater control gets the vacuum from. My 79 Bronco has a new motor and the person who put it in before i got it took off the poluction stuff.
So what is the sourse to make the vacuum to work the heater controls.
Can anyone give me some imput on this?
Heater Problems
Guest_Thomas 714_*
, Feb 20 2004 08:57 AM
Posted 20 February 2004 - 10:26 PM
A vacuum line feeds through the firewall and T's into a another line. This linethen goes to the back of the engine and the other side goes the vacuum resevoir on drivers side of engine compartment. As your looking into the engine compartment, line should be just to the right of the center line of the engine, just above the engine. Look for disconnected line or you may have a leak in your resevoir.
Posted 10 May 2005 - 06:50 PM
Since it's all ripped up- you start by locating the main line into the vacuum control (you must have Air Conditioning or else there's no vacuum lines). This main line (good luck finding which one it is) must connect to the engines intake manifold (where vacuum is made). I hope you only have one hose disconnected. Hope this helps.
