hey guys new to this forum and i really need all of your help i want to swap a 460 into a 84 f150 2wd it currently has an in line 6, would frame mounts from a 302 be useful and since i want to keep the manual transmission what else would i need please help me out thanks
460 engine swap
ed5.7
, Oct 03 2006 06:55 PM
Posted 07 November 2006 - 05:54 PM
Moved to correct forum by JSM84
When sawpping to a 460 from the 300I-6, you need both new motor mounts and frame perches. You could use the 302 supports, but still need the motor mounts from L&L Products or similar. I'm currently swapping a 460 into my 84 Bronco that had a 351W. IF you need more help, I'll watch this thread. JSM84
