been haveing problems with my 95 cant pin it down engine runs fine sometimes for days outher times only for minites ill be driving and the engine starts to cut out and dies alltogether no spark at coil wait 5-10min and it fires any suggestions. thanks mel.
Help!
Guest_mel_*
, Feb 27 2004 02:53 PM
7 replies to this topic
Posted 27 February 2004 - 05:10 PM
I would suspect the ignition module is going bad. You might try pulling the engine codes, and see if it's an ignition problem; or if your fuel pump is starting to fail it will cause similar symptoms.
#8 Guest_mel_*
Posted 28 February 2004 - 04:43 PM
fixed it it was-----------------------------------------------------------------------------------------------------------------------the f-n coil methed of diagnosis was tapping hard on the coil with engine running and it died then smacked it agian and it fired repeated 5 or 6 times thanks for the input mel p.s great site
