I WOULD LIKE TO ADD A CAM TO MY STOCK REBUILD 302 IT IS A 1990 F I50 REG CAB /SHORT BOX/ 4BY 4/ 302 V 8 /5 SPD WITH SPEED DENSITY IS THERE A CAM OTHER THAN STOCK WHICH WILL WORK WITH THIS SETUP . OR WHAT KIND OF CAMS ARE YOU GUYS RUNNING WITH THIS SETUP ALSO I WILL BE USING A FLOW MASTER FORCE 2 AND A K+N FILTER THANKS FOR THE INFO .
Speed Density
af ford able
, Mar 01 2004 11:53 PM
