I bought a 90 f250 lariat recently and when I bought it everything seemed to be allright. But now my rear turn signals are both flashing no matter which turn signal I use. The front ones are fine though, but now sometimes when I flip them on they stop. I have replaced the flasher fuse, but it still happens. Any suggestions?
Electrical Problems with 90 f250 7.4 litre
sbbeachboy
, Dec 29 2006 08:40 PM
Posted 31 December 2006 - 05:25 PM
It has nothing to do with the flasher, the same flasher element is in use for both. The only thing I can see is that there must be a short between the two wires, Orange with a light blue stripe (left hand light) and light green with a orange stripe (right hand light). The attached is from a 1983 EVTM but the circuit is the same with the exception of connector designations.
