New Engine
Posted 22 April 2008 - 06:34 PM
Posted 23 April 2008 - 06:09 PM
check with L&L the only thing you should need is motor mounts and frame mount.I am a new user here and I just threw a bearing on my 75 f100 it has a 360. SO instead of rebuilding the engine my girl friends dad offered to give me an 86ish 302 5.0l mustang engine that is in good shape and did run. I am curious as to what adapters I will need which I dunno where to find them. ANY IDEAS??? PLEASE HELP
Edited by Big White Bus, 23 April 2008 - 06:09 PM.
Posted 04 May 2008 - 03:23 PM
Good luck but you will need more than you think.The radiator will be fine but will need new hoses, motor mounts,frame mounts; exsaust system if it is stick then you will also need a bellhousing and probibly a z-bar bracket that bolts to the block because of the different block and if auto than a different tranny.I am a new user here and I just threw a bearing on my 75 f100 it has a 360. SO instead of rebuilding the engine my girl friends dad offered to give me an 86ish 302 5.0l mustang engine that is in good shape and did run. I am curious as to what adapters I will need which I dunno where to find them. ANY IDEAS??? PLEASE HELP
