I am planning on adding a 2" suspension lift to my 92. Going to use add a leaves in the rear and coil spacers up front. Will I be able to bring it back into alignment if I only add the coil spacers up front, or do I need the additional camber/caster adjusters, drop steering arm, etc.?
2" Lift
Guest_Koopa132_*
, Mar 09 2004 05:56 AM
4 replies to this topic
Posted 09 March 2004 - 08:03 AM
Check the camber bushings you have now, from the factory. If they are the offset ones, you will have alignment problems with just the lift coils or spacers. I would rather install a 2" body lift or trim the fenders before using coil spacers. Only thing holding them in is the single clip at the top.
Posted 10 March 2004 - 11:37 AM
That helps to know what you want to accomplish. My opinion, go with a 4" suspension lift, and stay away from the coil spacers and body lift altogether. The retaining clip I refered to is the one for the main coil spring, not the spacer.
