i have a 79 f150 explorer edition, it has a 460 in it with a c6 behind it, the problem i have is that it won't go into gear, it'll go into reverse fine without a problem and reacts to gas, but when i put it into drive it doesn't react to gas, it just idles and slowly creeps along regardless of the amount of gas i give it, i was thinking it was the seal behind the bell housing because it does have a slow leak in that area, but then again i've never messed with a transmission before so any and all advice is welcome
i'm tryin to get rid of it so i was wonderin if anyone had any suggestions as to why its acting like this and a possibly cheap rebuild kit if that's what it requires, or any other form of cheap fix
thanks
Edited by 76_Iron_Giant, 30 September 2009 - 01:34 PM.
