I just put a new rough country 4'' lift in my 1978 ford. It's leaning to the passenger side about 1 to 2 in. I don't know what is wrong with it, it wasn't leaning before when it was stock. Anyone have any ideas? Thanks
newly lifted 78 leaning to passenger side
tishmuffin
, Feb 15 2010 11:24 AM
6 replies to this topic
Posted 16 February 2010 - 07:37 AM
Assuming you have an adjustable rod, you may have to take off the end of the rod at the frame and see if the truck sets back level and readjust. If you installed a bracket, it could be mounted too high on frame causing rod to be too short and causing the axle to pull towards drivers side making passenger side appear to be leaning. That's where I would look first because thats typically the problem with leaning.
