86 Eddie Bauer Bronco
4 replies to this topic
#1 Guest_mjnort_*
Guest_mjnort_*
Posted 30 April 2004 - 03:21 AM
I have a 86 bronco,headlights went out ? checked fuses wires etc. any suggestions....
#2 Guest_Gunner_*
Guest_Gunner_*
Posted 30 April 2004 - 03:28 AM
bad wiring just like mine. my fix was to hot wire the switch and run wires from the switch to the headlights. you lose you high beams but it is a quick easy fix until you can get a new wiring harness.
#3 Guest_mjnort_*
Guest_mjnort_*
Posted 14 May 2004 - 07:38 AM
it was a headlight plug...was shorting out headlights
#4 Guest_Guest_redneckpunk_*
Posted 22 May 2004 - 04:01 PM
i really dont know what is wrong with your truck but i do have a
1986 eddie bauer bronco for sale real cheap if your interested send me a e-mail
all my info is on my profile
#5 Seabronc
Seabronc
    F-Series Commander
  • Moderators
  • PipPipPipPipPipPipPip
  • 683 posts
Posted 23 May 2004 - 07:29 AM
Check lead from fuse to Hi Lo switch. If you have voltage at the switch and neither Hi or Low work, the switch may be bad.
You might also want to look at the modification at http:/www.bigbroncos.com for improving the voltage to the headlights by directly feeding them from the battery rather than thru the voltage distribution system for the whole truck. It is under technical information.
I did a variation of that proceedure by getting a plow light harness. Details if you want them.
Good luck, :)>-
