Is it possible to take the dash seats and all out of a 95 and put it in my 79? how much modifying is there to do?
Dash
Guest_glidenonk2_*
, May 04 2004 08:57 PM
4 replies to this topic
Posted 06 May 2004 - 07:46 AM
The seat will bolt right in without any problems. Just installing the newer dash will be a killer. The hole dash on the newer model truck will completely unbolt from the firewall. cutting and forming the newer model dash will be your trouble side. even though it don't look it the newer model dash is anout 4" wider then your 79. I'm sure it can be done, But your fab skills will have to be good and don't plan on it to be a weekend bolt in job.
Posted 19 June 2004 - 08:52 AM
Aside from the seats, anything related to the interior will require mild, to extensive, modifications... IIRC, the 92-6 dash is narrower(not by much tho), and the door panels are longer
I had wanted to do that too, til I found this little bit out, and decided against it
