Anyone messed with their airbag, The aibag light is flashing a code at me, have
not looked it up as yet.
I am pretty Techno orientated but have never messed with the airbag and to tell you
the truth I don't really want too mess with it ,
but it could be a simple task that I may regret later taking it to the dealer to
fix......you know big bucks.......
Bret
Flashing Airbag Light
Guest_BRETS_BRONCO_*
, May 07 2004 03:22 PM
4 replies to this topic
Posted 24 July 2004 - 06:41 PM
Kelly, the # of times the airbag light flashes corresponds to the fault code it's sending you. I can't remember where I saw the printout of codes, but you might try a google search. Sorry I can't be of more help.
Posted 24 July 2004 - 06:50 PM
Kelly, I did a quick search, but this is all I found, It may be a starting point:
I found this in another Enthusiats forum. The link is http://www.ford-truc...ex.php/t-169332
This is the airbag code list for a 96 Explorer:
AIR BAG DIAGNOSTIC MONITOR DIAGNOSTIC TROUBLE CODE (DTC) PRIORITY TABLE
DTC.......LFC......Description......................................Action To Take
B1342....24........Internal microprocessor fault..............GO to Pinpoint Test A.
...................................(retrieved only during on-demand self test)
B1867...12/52....Lost battery feed or low battery..............GO to Pinpoint Test B1867.
...................................feed voltage
B1869.......- .....No air bag indicator - Inoperative.........O to Pinpoint Test C.
...................................indicator circuit
B1913......13/53.........Air bag driver/passenger circuit...................GO to Pinpoint Test B1913.
...................................short to ground
B1914......14/54.........Primary crash sensor circuit shorted...................GO to Pinpoint Test B1914.
...................................to ground
B1921.........21...........Air bag diagnostic monitor ground...................GO to Pinpoint Test B1921.
...................................circuit open or not mounted to vehicle properly
B1922.........22...........Safing sensor output circuit shorted...................GO to Pinpoint Test B1922.
...................................to battery voltage
B1923.........23...........Memory clear circuit improperly...................GO to Pinpoint Test B1923.
...................................grounded
B1924.........24...........System disarm failure or internal...................GO to Pinpoint Test A.
...................................diagnostic monitor fault
B1932.........32...........Driver side air bag high resistance...................GO to Pinpoint Test B1932.
...................................or open
B1933.........33...........Passenger side air bag circuit high...................GO to Pinpoint Test B1933.
...................................resistance or open
B1934.........34...........Driver side air bag circuit low...................GO to Pinpoint Test B1934.
...................................resistance or shorted
B1935.........35...........Passenger side air bag circuit low...................GO to Pinpoint Test B1935.
B1941.........41...........RH primary crash sensor feed/return...................GO to Pinpoint Test B1941.
B1942.........42...........LH primary crash sensor feed/return...................GO to Pinpoint Test B1942.
B1944.........44...........RH primary crash sensor not mounted...................GO to Pinpoint Test B1944.
...................................to vehicle properly or ground circuit open
B1945.........45...........LH primary crash sensor not mounted...................GO to Pinpoint Test B1945.
DTC - Diagnostic trouble code, retrieved using New Generation Star (NGS) Tester 007-00500 or equivalent.
LFC - Lamp fault code, flashed on air bag indicator.
I hope this helps.
I hope this helps.
Posted 24 July 2004 - 06:57 PM
One more thing, Kelly; the four then five indicated your Bronc is sending you a #45 code. In any case your airbags will not deploy when they are faulting like that.
