my bronco is eating through batteries. somehow its pulling power from the battery when the truck is off. i've checked the fuses by disconnecting the negative batt treminal and used a voltage reg but still nothing. how can find the problem without rewiring the truck? it also has a new voltage reg and new altenator
Wire Problems
bigbad79
, May 24 2004 10:56 PM
Posted 25 May 2004 - 07:21 PM
Can you see a discharge registering on the amp meter? Sounds like you have a short, probably a positive wire that has rubbed thru and touching someplace on the chassis. Removing the negitive terminal won't help if that's the case. If it's not a dead short or if the short is ahead of the fuse block no fuse will pop. Give a carefull look at the wire harness, roll it over especially any place it is directly touching metal.
Good Luck,
Good Luck,
