Having problems with 77 f-150. Truck has been sitting for two years, and I'm trying to get in running again. Just replaced part of a fuel line that was leaking. THe truck will start and run if I pour has in the carb. But it eventually dies. Can't seem to figure out the problem, but doesn't seem to be getting fuel to the carb. I pulled out the fuel pump, but it seems to be alright. I think I will replace it just to be sure. Does anyone have any other ideas as to why fuel doesn't seem to be reaching the carb, and the truck won't stay running. I'm running out of ideas, and would love to get the truck running for my husband. Thanks
Fuel Problems
Guest_sully_*
, May 25 2004 09:10 AM
6 replies to this topic
Posted 25 May 2004 - 06:46 PM
Ditto on the filter. You can leave your hose disconnected and crank it over to see if the pump is pushing gas. You should get a pretty good spout of gas comming out of the line.
You can try blowing back thru the fuel line to see if there is a restriction between the point where it attaches to the pump and the tank. You should be able to hear bubbles if you leave the cap off the tank. An old tank can have a lot of crap in it that could get stuck in the pickup.
Good Luck,
Good Luck,
Posted 25 May 2004 - 08:11 PM
Replace them all. You may have some water in your tanks as well. Since water floats on gas, you'll be sucking water off the bottom of the tank until you get rid of it all. Depending on how much water you have (if you have it), you can add alcohol to the tanks and this will help break up the water.
Posted 26 May 2004 - 01:14 PM
If you have two tanks, it could be the fuel selector switch. I had the same problem not to long back.
I'm also wondering if the truck has been sitting? If so add a gas additive called "Heet" which will evaporate any water in the tank. The tanks could be clogged at the pick up if the filter changes don't help. If you run a mechanical fuel pump, you can pull off one line at a time and feel for suction on one side and gas will spray out the other one. Watchout for gas in the eyes! It will sting for a few minutes... If its an electric pump, disconnect the hose just after the pump and see if its flowing.
Wheel it like you stole it!
Posted 26 May 2004 - 02:26 PM
I was driving up the road this afternoon and it occured to me that you said ylou have 2 ttanks. The selector is definately a probable cause. I assume that you are not getting gas no matter which tank you choose. Try bypassing the selectorsolenoid
